320/6 radiator is leaking (nou sure exactly where from yet, definately not a hose though.)
At some point i will change engine to a 325i, which i assume comes with a rad upgrade. Is there a way to avoid replacing the radiator twice?
Leaky Radiator
- cdavie2002
- e21-Mark
Re: Leaky Radiator
I still used the 323 rad with my 2.5 so if you get it refurb'd it won't be a waste.
- cdavie2002
Re: Leaky Radiator
Good to know, thanks!
What if i wanted to upgrade to an alloy radiator? Benefits? Fitting issues?
Thanks in advance for your help.
Chris
1982 320/6 (breaker)
1975 3.0 csi
1974 3.0 csi (donor)
2003 E46
1975 3.0 csi
2003 E46
- e21-Mark
Re: Leaky Radiator
Benefits are more efficient cooling. Just get a direct replacement although they're not cheap. I'm ringing about mine tomorrow and will let you know costs.
- cdavie2002
Re: Leaky Radiator
Forgot to mention, car has auto box. The radiators on autos are different, will it still be compatible with a 325i?
Chris
1975 3.0 csi
2003 E46
1975 3.0 csi
2003 E46
Re: Leaky Radiator
no you can use auto rad on a manual but not the other way round.
- cdavie2002
Re: Leaky Radiator
Who supplies direct replacement aluminium radiators?
Chris
1975 3.0 csi
2003 E46
1975 3.0 csi
2003 E46
