http://cgi.ebay.co.uk/BMW-E21-Front-Rea ... 3f05717169
looks fairly reasonably considering they give you all major bushes
when i bought my superflex bushes nothing was available for the front arms
polybushes on ebay
- quinn_656
polybushes on ebay
My build
www.quinnpiling.com
www.quinnpiling.com
- JTY
- My E21(s): 1981 323i
Re: polybushes on ebay
Looks rather good! I had a look at their website: http://www.strong-flex.eu/index.php?pag ... t&Itemid=1
- petroscf
Someone PLEASE explain to me what gets better, and what difference there is in driving feeling with poly bushes instead of factory rubber ones?
P L E A S E !!!
Mark has tried once to make me understand but it seems I am a bad-bad learner...
P L E A S E !!!
/oo=00=oo\
E21 Forever
E21 Forever
- quinn_656
well the idea is you should feel less movement with the harder bushes because they are stiffer and therefore will resist movement moreso than the soft original rubber which is designed for comfort.
the main benefit in my opinion is that unlike rubber polyurethane does not perish (doze) and the kits usually come with stainless steel inserts to prevent the bolts from seizing therefore in theory you can put them in and forget about them.
a simple upgrade if your having to replace bushes anyway
My build
www.quinnpiling.com
www.quinnpiling.com
