Auxiliary gauges
- --ALPINA--
- --ALPINA--
- --ALPINA--
OK mark, i was looking thru my archive again and i knew i had some info for ya.. so hope this works.. it shows VDO but its the same shit..
http://homepage.ntlworld.com/john.combes2/Vdo.htm
J
J
- e21-Mark
- Sierpien
- My E21(s): C1 Turbo Alpina tribute, 316 Sepiabraun
- Facebook page: https://www.instagram.com/fedecx5aa/
I like my setup
Alex von Falkenhausen
- petroscf
Ok, if I understood well, the senders are some kind of wires, aren't they?
In case of gauge-pods fitted on top of the dash (as it's the case with most E21s), where do the wires pass from (inside the dash) to reach the engine bay? is it needed to pass them from the ventilation ducts that are exactly behind the pod (then the wires would be visible, which I wouldn't like at all) or can one pass them inside the factory speaker hole, under the pod?
/oo=00=oo\
E21 Forever
E21 Forever
- e21-Mark
Baron Von Franzen
- Newbee
Re:
Hi there from Bimmerforums/Australia, sorry to resurrect an aged thread but I just bought this very same tri gauge cluster and I was wondering where you would get matching vdo gauges to fit the size of the gauge holes. I'm after Oil pressure, oil temp and I'll have a wideband O2 sensor in there too.--ALPINA-- wrote:Hi mark as said, my current stup in my car is below, hope this gives you an idea!! if anything ill guide you thru wiring if your not sure mate!! The oil Temp isnt connected, will be when i fit a mocal oil cooler..
J
Thanks heaps guys.
Hal
- e21-Mark
Re: Auxiliary gauges
The gauges from an Audi coupe, or similar, will fit fine.
Baron Von Franzen
- Newbee
Thanks for the reply brother, which ones are in "Alpina's" picture? I actually wouldn't mind those exact ones.
