rob0r
Post by rob0r »
Yes!!
First time I've driven an E21 on the road in 4 years, and first time this car has been on the road for at least 6... It flew through it's MOT with no advisories!
Duracel79
Post by Duracel79 »
Pulled out the broken engine at the weekend.
And fitted a standard ish 325i engine, its all in and running just needs a remap. Which is happening 14th March.
Ben
Jason_323i
Post by Jason_323i »
Started to rework the front suspension
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
oldschool e21
Post by oldschool e21 »
lol how the f*** did you do that!?!?!?! :shock
drjim
Post by drjim »
Today I removed all the bits of trim that had been chucked in the car and put it all out of the way on my racking. Then I removed the seats. I did more sanding and priming of the doors and rear arches. Before setting off for the workshop I drilled out the spot welds holding the boot side panel protecting brackety thing in the slug, took the bit to the workshop and welded it in to the Baur. The floor was a bit thin under it, so there's going to be a couple of spots where holes are filled with seam sealer rather than metal (drill sized). Then I did a bit of sanding of the door handles and baur side panel things.
Finally I had a chat to Shaun about painting the car next week.
Progress!
1982 Saphirblau Baur 325i
Cars all gone!
Had camshaft oil seals replaced and re-routed breather hoses to catch tank on inner wing. Cleaned engine bay and went for a test drive to check everything is as it should be.
bassboy3313
Post by bassboy3313 »
so my car was running like poo when I got it. was told that there was a vacuum leak and that would fix the problem. turns out that the timing was way off and the idle screw was cranked up to make it seem driveable. I adjusted the timing, turned down idle screw, replaced +ve battery cable, replaced spark plugs and oxygen sensor. Runs a lot better, but not perfect yet. slowly but surely.
1983 320i
century turbo kit
volvo turbo k-jet fuel upgrades
vw SS injector lines
2.5" SS exhaust
chevy sb aluminum radiator
water/meth injection
alpina front spoiler
mono wiper conversion
3.91 lsd conversion
e30 ellipsoid headlight conversion
arshad76
Post by arshad76 »
Mini Valet at my mates place.
UK Moderator
Took the race car round the block to bed new brake pads in. Just the seat to do and it's ready for Crystal Palace. :)
Swapt the wilwood fast road brake pads for ferodo ones ..
DC
Post by DC »
e21-Mark wrote:Took the race car round the block to bed new brake pads in. :)
same - and new brakes works awesome :-)
getting ready for our two racing circuits
Image <- 320i Turbo
Danny043
Post by Danny043 »
Continued taking the 318i apart:
murran
Post by murran »
went on a drift day on sunday at blyton airfield. gave the car a good thrashing, killed 4 tyres and got it really dirty.
also put a man sized dint in the n/s sill while sliding thru several cones. that bit im not so pleased about!
today i picked up some vw corrado bbs wheels to fit on the back at driftdays and started stripping the old paint off my (soon to be fitted) rollcage.
Murran can you keep us posted next time you go drifting please? Would like to spectate.
pistonheader
Post by pistonheader »
wiz0r wrote:Yes!!
:popcorn
well done rob!!! know it's been a lot of work and glad it's finally sorted!! now, i just need an excuse to drive to colchester :lol:
