- e21-Mark
- Bempie21
- My E21(s): E21 '81 323i
- Facebook page: https://www.facebook.com/deukjesdokter/
I resprayed the my engine (inlet manifold) with a special coating/paint.
What did you use then?with a special paint.
fitted my roll cage!! woo hoo. im really chuffed! (cant find the damn camera lead tho grrrrrr!)
I looked at the small hole in the spare wheel well where the drain plug thingy is, only became apparent when I wire brushed some loose underseal off the other day, and decided I'm going to have to chop it out and weld a proper patch in - thought I had finished welding this car!
1982 Saphirblau Baur 325i
Cars all gone!
Cars all gone!
- DrGonzoPOW
- DrGonzoPOW
There is no end Jim! You should know this by now!drjim wrote:thought I had finished welding this car!
Wakefield Hellfire
- Bempie21
You like it???Wondermike wrote:What did you use then?with a special paint.
The engine hood holder as you see there, is the same coating as the inlet manifold.
Full speed ahead!
Replaced most fuel hoses last year (op top of the right tank half and to the pump) but after that work I noticed a drop of fuel on the left half after fueling as well. Time to remove...
Rear subframe has some superficial rust but not enough to annoy me atm
Oh yeah that one's been leaking! Further, no rust or traces of leaks on the seams
If you payed attention
you already noticed the missing rear sway bar. Time to fit the Alpina unit that Arnold has freshed up for me
And now the car's jacked up anyway...
New 325 engine is in and was mapped yesterday (193bhp)
Fitted the fibreglass front wings and bonnet as well.
Ben
Ben
- e21-Mark
Glad you've got it up & running again Ben! Are you coming to PPC shoot?
- e21-Mark
I cleaned up the powder coated parts I have for the engine bay on the TWR.
Did my usual weekly oil & fluids check on MIB before giving it a wash.
Fitted new front and rear windscreen ..
- DrGonzoPOW
oldschool e21
- E21 starter
i fitted my new hazard light switch £39.00 from bmw ouch!
