DrGonzoPOW's 1981 320/6 - 325i -Race'in Up-
DrGonzoPOW
Re: DrGonzoPOW's 1981 320/6 - M20B25 It Begins!
Post by DrGonzoPOW »
What am i going to need then Jim? Type of wire, thickness, gas all that gear? (i know you've told be before so sorry). I have no clue about welding but guess i need to learn
Wakefield Hellfire
Check you-tube for mig welding basics.
murran
Post by murran »
you got a good pic of the bit that needs welding? what welder is that one under the bench? has it got any wire in it already, if so, what type? have you got a regulator for some gas?
drjim
Post by drjim »
murran wrote: what welder is that one under the bench? has it got any wire in it already, if so, what type? have you got a regulator for some gas?
It's a clarke pro 90 with a new torch fitted as the old one was knackered. He has a regulator for argon or CO2 bottles although the LPM gauge got bashed when the bottle fell over. No wire in it.
1982 Saphirblau Baur 325i
Cars all gone!
DrGonzoPOW
what he said
Wakefield Hellfire
DrGonzoPOW
Re: DrGonzoPOW's 1981 320/6 - M20B25 conversion
Couple of jobs done today. Mostly things still on hold due to the welding issue but think im gonna have a crack at it myself now (oh dear). Grinded and wire wheeled it all back and its not actually that bad. The inner skin is very solid so i just used some rust eater and caked it in U-Pol weld thru primer
Still just cleaning and re-painting stuff until thats sorted. Did the block in high temp blackness
Buffed the head up with a drill mop and its looking nice so no paint on that.
And most of the day was taken up by getting the new member into the Fantasy Factory
Has a 1.8 supercharged Corrado engine in. Just needs bolting back together and tidying up and it'll be a nice little weapon indeed!
Wakefield Hellfire
murran
Post by murran »
motor looks good dude, niceo'shiny! did you clean up the sump or are you leaving it with the protective anti-corrosive layer of oily dirt (like i suggested)?
you do any practice welding?
DrGonzoPOW
Went for anti corrosion muck mate :) Need a mask before i can try welding. Ive ordered one so will be able to have a crack soon.
Regarding the battery boot jobby. Did you just use a standard jump lead cable and attach some terminals to it ? Think i may have to do the same as that E30 one does'nt really bend into places very well
Wakefield Hellfire
murran
Post by murran »
yeah i used a heavy duty long set of jump leads and some m8 crimpable terminals from halfords.
DrGonzoPOW
Tried my hand at welding today and think i may just attempt the patch myself. Still working out the best power settings and wire speed but getting some half decent welds on some scrap i pinched. May possibly have a go tomora if im feeling confident, think im just gonna use some 1mm steel like the bits ive been practicing on to bodge a patch. Really fed up with everything being on hold because of this hole!
On another topic i bought some proper 143 Kashmir metallic paint......but the colour is way off so pretty gutted about that as it was 30 quid! Also bought a half decent gravity feed gun but seem to have glogged it all up already and it needs taking apart and properly cleaning. Painted all the headlight fittings, servo and sunroof patches up though so all was not lost today. May attempt to put the sunroof back together again soon but i need to figure out how to lower it slightly as it scratched the sh*% out of it when opening it before.
I also managed to get a snapped stud out of my cylinder head which id just about given up on, so pretty chuffed about that.
Wakefield Hellfire
Good work. I say go for it with the patch. What's the worst that can happen? You grind it out and try again!
DrGonzoPOW
Update one the welding......
This has been cleaned up alot but happy with the results
Might fill it a bit to smooth things up a tad. Anyway the swap is officially back on track :banana
Next step is engine in!
Wakefield Hellfire
Jobs a good'un! :thumbsup
DrGonzoPOW
Drain hole she wee painted
New seal on panel
Dropped a bollock with that part. Got a bit messy with the tiger seal so i cleaned it up with some cellulose thinners which also took off some of the felt on the rubber :wtf
I hope that felt layer is just for asthetics and wont effect the seal !!??
Wakefield Hellfire
murran
Post by murran »
the important bit is the drains working. the weather seal is not as important.
patch looks good to me!
need a hand putting the engine in? i might be free sometime over the next couple of weekends. give me a day and i'll try to get authorisation from our lass..... sort of a day release from family life if you will......... let me know dude! more notice the better!
