BMW Badge
nicks85
BMW Badge
Post by nicks85 »
Hey all,
I was thinking of getting the badge threaded so that I can use some nuts to screw it down securely.
Or, use some strong glue?
Any ideas?
Cheers
m3gaz
My E21(s): looking
Re: BMW Badge
Post by m3gaz »
I take it we're talking about the roundel on the bonnet or boot.My advice,for what its worth,is to get some new little rubber reseptical grommet type things and just fit it as normal.If some dipshit decides to nick it then there's no damage.Fix it solid and they start with the tools. :hammer I've been there courtesy of The Beastie Boys! :wtf
Re: BMW Badge
+1!
nicks85
Re: BMW Badge
Post by nicks85 »
That is a good point.
Any idea what type of glue I could use?
m3gaz
My E21(s): looking
Re: BMW Badge
Post by m3gaz »
No glue,they just sit there and even at 120mph they don't move :launch
nicks85
Re: BMW Badge
Post by nicks85 »
m3gaz wrote:I take it we're talking about the roundel on the bonnet or boot.My advice,for what its worth,is to get some new little rubber reseptical grommet type things and just fit it as normal.If some dipshit decides to nick it then there's no damage.Fix it solid and they start with the tools. :hammer I've been there courtesy of The Beastie Boys! :wtf
Ok, cool, where can I get hold of some of those rubber resptical grommets?
Re: BMW Badge
Double topic removed, with 2 grommets from the dealer that set you back abt 2p the badge will be secured in place again. Don't use glue.
nicks85
Re: BMW Badge
Post by nicks85 »
Ok, thanks Jeroen
nicks85
Re: BMW Badge
Post by nicks85 »
Sorted 84p each, will be with me in a couple of days :-)
nicks85
Re: BMW Badge
Post by nicks85 »
I meant 64p each :-)
Should I get some for the rear as well? Seemed to be a little loose
Re: BMW Badge
Works just the same...
