adjustable top mounts.....anyone running them....?
hi,
Wanna dial in some serious front camber on the e21, have seen adjustable top mounts but wondering if anyone is using them?
Also is there any other way to get front camber...?
Cheers
Arron
Cheers
Arron
- Jason_323i
Re: adjustable top mounts.....anyone running them....?
Yeah I am use them get about 3deg neg out of them but I also have a modifeid front subframe and adjustable track control arms and get near 10 deg on full adjustment.
the other way is to lower the car modify the front subframe, fabricate some new strut tops with offset mouting holes.
I guess you are concerend about looks than handling.
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
i am lol
that looks a tad ott for me as i dont weld/have a welder etc does look awesome though!
- e21-Mark
I use K=macs and RPM but nowhere as extreme as Mr Jasons.
id like some rpm ones. i dont have £200 though!
i need some top mounts, Maybe a group buy is in order?
- e21-Mark
I'll ask and see if RPM are up for it if you like?
yeah if you could that would be brilliant - i reckon we would have to order lots of them though.
to be blunt here, in my current financial sit. concidering the other stuff i need to buy/sort out.... theyd have to be sub £100 to tempt me at this point.
id also bought some adjustable bolts with the eccentric washers, like the rear wishbone mount ones infact. guna do the the lower arm mount on the subframe.
widen the front track and add a touch of camber along with some all important castor hopefully.
id be up for a set from rpm if on a group buy... the cheaper the better though...
e21 335i gone but not to far.
e21 316.. still
ford puma..(wifes honestly)
e21 316.. still
- e21-Mark
I'll email or call them and see what they'll do on a buy of 10 sets. I can't see a reduction of 50% being on the cards though tbh. Anyway, I'll mail them now.
I'm sure Jimmy will bow to a bit of persuasion from you Mark
Yea I'm reaching the limit of reason for spending as well, hefty price reductions please!
if you get 10 mark hold on to a set for me. then i can save up for them. maybe end of june i can paypal it to you?
