e30 2.7 stroker up and running (warning one zillion photos)
It hase been covered already in the dutch part of the forum but I like to share here also what I haven been doing over the last 4 months ... playing with my new engine .. a 129hp B version eta engine was the standard set up ..
e30 323i lightened flywheel 6,2 kg's
balanced cranck shaft
all conrods have exactly the same weight ..
all pistons have the same weight as well ..
everything painted in a heat resistant coating ..
next step was the cilinder head but this has been done by a machine company :wink:
Re: e30 2.7 stroker up and running
some futher updates
engine rebuild with pistons, new piston rings etc ... block is skimmed 0.2 mm
reworked outlet ports of the 885 head .. right side has become 5mm larger in diameter to become a perfect fit with the exaust tubes .. the head is skimmed 0.3 mm
finished result ...
inlet ports original
raughly reworked
and finished...
putting the pistons in the engine
new rockers and double valve springs
valve stem seals
new double valve springs
thats how we did that
fresh new dbilas cam shaft .. and here you can also see the reworked rockers (they are made a little lighter)
we first test fitted the head on the engine to find out the free space was not enough (only 0,5mm)
so we had to work on the pistons .. to clear the valves a bit more
raughly reworked
and finished
again test fitting
and satisfied now 1,9 mm and when the head gasket was tightened 1,2 (0.8 is a minimum to be safe I was told)
waterpump and distribution gears in place..
and everything as it should be
everything put back together ready to be moved over to my garage where engine swap would take place
So when everything was home the engine swap could begin :banana
and out she goes...
old an new side by side :D
more to come
New injectors in place 10% increase of capacity they are from a ford mustang but are also fitted on the e36 325i engines
alternator, starter motor and some more things on the egine
wiring loom for the 173 type ecu partly mounted
exaust manifold, dizzy and spark wires mounted
test fitting with my biggest friend :thumbsup
serious then ...
finally after 2 hours of sweathing engine and gearbox are bolted under the car again
Nice work started after those thing finished .. connecting the old type square c101 connector on the new round one ...
this is what I mean with square to round connector ...
connecotrs of and everything marked
and then soldered together again following this little scheme
done for now ...
2 more wires have to be replaces .. one for the econo gauge and the other for the engine speedometer .. black from engine loom to black in the yellow connector under the dash (rpm gauge) and white/black from engine loom to yellow/white in yellow connetcor under the dash
and tis is how it looked 2 weeks ago
and this is how it looks like when finished
The engine is running on the the alpina b3 2.7 version ecu and is good at the moment .. good decent push under 3000rpm and from 3000 onwards she goes really fast .. Still running in the pistons rings a bit so max rpm for now is 4000 with some peaks of 4500 ... max rpm is set to 7000.
First 750km is yet on the clock and she isn't using any water or oil ...
Power output shoud be somewhere around 210 bhp and torque would be between 270/280 nm
We will know for sure when she goes on the power bank for testing hopefully somwhere later this year
Gerrit
Re: e30 2.7 stroker up and running (warning one zillion phot
Also in English nice pics!! Respect for all the work!
