Wellers etc
Wellers etc
What wheels in the weller style will actually fit? for example these:
http://cgi.ebay.co.uk/2-Weller-Wheels-7 ... 500wt_1156
And what types should i be looking to buy, the cheaper the better preferably
Re: Wellers etc
yeah, definitely wasnt going to buy them at that lol, but question is, would the buggers fit?
Re: Wellers etc
he says they fit vw/vauxhall so i guess they will, as the 4x100 and 57.sumurt center bore is the same .... tho it doesnt actually say the offest (et) is in the add. (??)
Re: Wellers etc
what bore size are e21's 57?
- e21-Mark
Re: Wellers etc
Yes, but Vauxhall ET is 35 I think so you'll probably be needing 20mm spacers.
Re: Wellers etc
nice one, cheers, i think wellers or banded steels are going to be the way forward
Re: Wellers etc
can you fit 13" wheels with a deep back over the front brakes?
- e21-Mark
Re: Wellers etc
Try fitting a standard steel on back to front and you'll be able to tell.
Re: Wellers etc
good plan mark, cheers for that, a bit obvious really lol, but sometimes you just need other people to point it out!
Re: Wellers etc
e21's bore 57.1
Re: Wellers etc
cheers for that
Re: Wellers etc
lol.e21-Mark wrote:Try fitting a standard steel on back to front and you'll be able to tell.
- e21-Mark
Re: Wellers etc
Vauxhall ET is 35 iirc and VW ET varies between models.
Weller do actually do a steel rim with the correct offset for an e21. I'm just waiting for them to come back to me with a price and rim sizes.
Re: Wellers etc
vw 4x100 wheels 13, 14 and 15" generally can be owt between et33 and et45.
