Baur rebuildathon - ON THE ROAD
Re: Baur rebuildathon = ALMOST DONE!
Thanks for that Jim. I can't tell you how much better I feel knowing it's not only me that that stuff happens to. :)
Hopefully this sunny weather will still be around when you start driving the Baur!
drjim
Post by drjim »
Hopefully the sunny weather lasts a while - just cooking Dinner and noticed a large puddle of water under the boiler, central heating circuit has sprung a leak, fortunately it has leaked all over the tiled kitchen floor, but it'wasn't in my plan for tomorrow.
1982 Saphirblau Baur 325i
Cars all gone!
I remember when this was a bareshell!
drjim
Post by drjim »
It now looks like a car, needs a bit of touching up to the paint and proper cleaning.
Bare shell was actually two years ago - I suspect I will win a worlds slowest restorer even though a load of Mates came and helped award!
Hopefully get 5-6 hours on it tomorrow, in the home straight!
Cars all gone!
mr edd
Post by mr edd »
Jim! I think i iam more likely to earn the award for slowest restoration ....1996-2011 and still going (slowly)....lol...edd
e21 316 (1981) TRE702X.
drjim
Post by drjim »
Managed to get the interior back together, ECU wires a bit sticky out in the passenger footwell, but can live with it.
Started filling the rad with water/antifreeze when I heard a gushing noise. Further inspection located Murran's post-it with "little hose from back of block to throttle body finding and fitting" written on it. I'll be using some fuel hose I have spare.
I need to do that hose, bleed clutch, tighten rear hub nuts and fit pins, connect battery, add petrol to tank and see if it works. Sadly the central heating leak was more of a problem so I am working throughout my week off to raise cash for a new boiler. Car will be done soon, it's been 2.5 years already so a couple more weeks won't be a disaster. Have my eyes on a merc 500SEL to play with next.
Cars all gone!
murran
Post by murran »
drjim wrote:located Murran's post-it with "little hose from back of block to throttle body finding and fitting" written on it. I'll be using some fuel hose I have spare.
classic. :wha
drjim
Post by drjim »
Managed an hour today, dismantled the inlet side of things to fit that hose, made a bracket to hold the AFM (flipped as per Gonzo), sprayed it with some paint and then while it was drying poured some more water into the header tank. It all came out again - hose to header has no clip on it at the pump end. Very tricky to get at from the top with a bonnet fitted, ramp was full of a Ka, so fiddled with it until I got the jubilee clip in place, and it still leaks. Not sure if it's that hose or another. Need it on the ramp so I can see where the water is coming from.
Decided to have beer tonight instead of workshop, working Tues/Thurs and out weds.Friday night and then if I can convince the Wife, I'll get it finished at the weekend. It really is down to piddling little jobs and snagging now. Good news is I have enough cash to pay for a new boiler now.
Cars all gone!
DrGonzoPOW
Post by DrGonzoPOW »
Have you blanked off that hose that comes from undernearth the inlet manifold mate ?
Wakefield Hellfire
drjim
Post by drjim »
What hose is that??
There's hoses that come to/from the throttle body with water in, the two that connect the brake booster to vacuum, and the ICV air connection. Don't tell me there's another feckin hose there!
Given that you are somewhat ahead of me on the M20B25 front I'll wait to hear which hose I don't know about is the likely problem!
Cars all gone!
DrGonzoPOW
Its in the middle and underneath the inlet manifold throttle body. I just cut mine and blocked it with a wheel bolt and jubilee. I think its number 18 on this diagram.
Wakefield Hellfire
drjim
Post by drjim »
I've got that one fitted, what I'm not certain of is what is connected up to the water pump properly. Between me and Murran there's been a bit of sticking hoses on without clips meaning they leak everywhere. Need to get it on the ramp so I can look at it.
Cars all gone!
DrGonzoPOW
Are you using the E21 water pump and expansion tank ?
Wakefield Hellfire
drjim
Post by drjim »
Yep it's an E21 pump so far as I recall. suspect that means there's nowhere for that hose to connect to and I need to blank the cursed thing off!
Cars all gone!
DrGonzoPOW
Indeed herr doctor!
Wakefield Hellfire
