exhausts
mattymoo2
exhausts
Post by mattymoo2 »
Has anyone had any luck with finding exhausts for there e21?Im in need of a complete system and want to spend as little as possible.I ve seen a few companys on ebay and had a quote from main bmw garage.thanks for any help.oh and the a 320/6
Matthew
DrGonzoPOW
Re: exhausts
Post by DrGonzoPOW »
You can still find middle sections, backboxes and manifolds easy enough on ebay, but front pipes seem to be a bitch to find. So if you see some id try get em. If you want cheap, then standard parts may take you a while to aquire.
Wakefield Hellfire
murran
Re: exhausts
Post by murran »
front pipes for 320/6's are the same as the 323i's if it helps?
how badly is yours knackard? which bit?
DrGonzoPOW
Re: exhausts
Yeh they are. I still had trouble finding em.
Wakefield Hellfire
louisE21
Re: exhausts
Post by louisE21 »
my front pipe had to be cut and a new section welded in yesterday. snapped right around where the mount is just before the mid section on 316. thats the trouble when you slam your car :@
mattymoo2
Re: exhausts
Post by mattymoo2 »
Have had the front two pipes welded for the time being.Dont think its going to last much longer as there so rusted.Back box is only a few years old but in need of replacement.May have to get the two front pipes from the main bm dealer and middle and back sections of ebay,should all fit together.thanks for the help.matt
Matthew
