DrGonzoPOW's 1981 320/6 - 325i -Race'in Up-
DrGonzoPOW
Re: DrGonzoPOW's 1981 320/6 - M20B25 conversion COMPLETE :)
Post by DrGonzoPOW »
Had a fiddle this morning. Changed the idle valve, air flow meter (right way round) tightened up all the hoses, checked for leaks.... and still does the same thing which is rev's dropping very low before going back to idle. The only thing i can think of is the chipped ECU i got from the bloke i bought the engine off. If its just a shit chip could there be a problem with fuel supply eg over-fuelling and choking it up slightly ?? It does smell a bit strong
Wakefield Hellfire
murran
Re: DrGonzoPOW's 1981 325i - A Few Niggles....
Post by murran »
ive got a standard 320 ecu in the shed. i'll bring it with me tomorrow.
DrGonzoPOW
Cheers Murran, but i have a 320 one already.....infact ive just tried it, and it goes back to idle fine with that. The fuel mix and timing must be loads different on the chipped one i have. Mind you, it is f**king quick with it on!
Wakefield Hellfire
DrGonzoPOW
Well idle issue is sorted, but now it seems that my heater isnt working and the cars temp guage is going a little higher than im comfortable with when sat. Anyone had problems with theirs ??
Wakefield Hellfire
DrGonzoPOW
Couple pics with new wheels on
Does anyone have any knowledge about the heater matrix and valve ? Cars running a bit hot, and the blowers will only blow cold air
Wakefield Hellfire
murran
Post by murran »
might have a bit of air in it since the conversion.... give it bleed up at the heather pipe on the baulkhead.
loosen the jubilee off and pull the pipe off abit. top it up at the expansion tank till it comes out at the matrix pipe and shove the pipe back on while coolants coming out if you know what i mean?
then bleed it at the 8mm headed screw on the thermostat housing afterwards.
DrGonzoPOW
Er....hopefully that will make sense when im doing it :)
Wakefield Hellfire
murran
Post by murran »
hows it running dude? any progress on the overheating?
GixxerBob99
Post by GixxerBob99 »
Looking nice
DrGonzoPOW
Cheers Bob!
Have'nt bled the system yet mate, will prob get round to it this weekend
Wakefield Hellfire
jimbob
Post by jimbob »
looks great
has the conversion made a huge difference or marginal
E36 328i Daily driver
E36 328i Touring
murran
Post by murran »
from the way the back of daves car sits down and then disapeers off into the distance when he boots it. id say pretty huge difference lol.
even nas said last weekend (at the mini meet we had) that he was "almost" having trouble keeping up with him......
DrGonzoPOW
Haha, just read that. Yeah man, its fooking rapid! Its all low end stuff tho to be honest, i have to drop gears to get it shifting. Just been out for a razz today but it looks like the chuffing slave cylinders packed in. Just nursed it home from the mean streets of Barnsley.
Wakefield Hellfire
Check your thermo coupling thing. When I had one and it was just starting to fail, I had similar problems.
Or the sender, wouldn't be the first one giving up either. For the rest, wonderful car and yes, that powerplant should make quite a difference indeed!
