Advice needed - Alloys and tyres.
- Enda
Re: Advice needed - Alloys and tyres.
These will get too expensive for me, VERY nice though (Despite their branding!): http://www.ebay.co.uk/itm/150651712987? ... _500wt_998
My avatar shows a car that I had to send back to the UK from Ireland.
Very shiny on the outside, soft and rusty on the inside..
Still searching for a nice solid E21, on a shoestring!
- Enda
What size tyres are you guys using? For the Slot Mag Reissues (http://www.wolfrace.co.uk/40th_details.php?wheelID=244); I was recommended 195-50-15.
- e21-Mark
195/50's will be fine. You can go to 205/50 on the rear or even 215/50 with a bit of arch rolling.
- Enda
Hi Peter, did you need spacers, or did the wheels fit straight on? Thanks!
Peter V. wrote:So you want the 15 inch BBS alloys for the BMW E21. That would be the Mahle version with ET13 and then in 6,5 J or 7J. We have 7J on our 316 and it looks like this:
- Enda
Would these be too wide anyway, even with these tyres on:
8x15", 4x114.3 pcd, ET43
185x45x15 Tyres
185x45x15 Tyres
Enda wrote:These will get too expensive for me, VERY nice though (Despite their branding!): http://www.ebay.co.uk/itm/150651712987? ... _500wt_998
- e21-Mark
They're the wrong PCD. You need 4 x 100. ET13
- Enda
He said he could supply adapters, at an extra £120..
Will forget about this one I think!
e21-Mark wrote:They're the wrong PCD. You need 4 x 100. ET13
The BBS wheels we have are a straight fit. No spacers or whatever. You only need to know that BBS uses longer wheelbolts.
They are 7J with ET 13. The tyres are 195/50/15 Bridgestones.
- Enda
Thanks Peter, I located a set but they are ET24
Peter V. wrote:The BBS wheels we have are a straight fit. No spacers or whatever. You only need to know that BBS uses longer wheelbolts.
Those are probably a set off 15 inch BBS from the BMW E30 series. Is not a big problem but you need spacers at the front of 10 to 15 mm. The back is no problem. I had those on a E21 as well.Enda wrote:Thanks Peter, I located a set but they are ET24
pictures of borbets......
- e21-Mark
- Enda
Thanks for that, they look well on your car.. I'll have a look into pricing for spacers and longer bolts!
Peter V. wrote:Those are probably a set off 15 inch BBS from the BMW E30 series. Is not a big problem but you need spacers at the front of 10 to 15 mm. The back is no problem. I had those on a E21 as well.Enda wrote:Thanks Peter, I located a set but they are ET24
- Enda
Tasty!
louisE21 wrote:pictures of borbets......
- Enda
I got these from eBay Germany, for €271 inc delivery:
They're 15 - 7J - ET24, so I need to get those spacers and bolts, I think Demon Tweeks have them..
