Jason,Reck wrote:I took my clocks out the other day and snapped the small solid circuitboard behind the handbrake/brake warning lights when removing the little blue plug. I superglued it back together and soldered the path so I *think* it's working okay. However when I first plugged it back in my brake warning light came on (which I've never seen before) but then went off, and the fuel gauge was going wildly between 1/2 full and empty. Now the fuel warning light is on and I don't know if to trust it anymore because of the snapped circuit! Do you know what this circuit is for?
Also another question, I forgot how to route my speedo cable - does it go under or over the mounting point for the clocks?
The wild fuel gauge indicates a groudn problem, I had the same. I dd not try to figure out the entire wiring and circuit board, but these circuits do influence each other so I strongly recommend te replace the white plastic part as a whole. What I do know is that you can always trust the warning light, so if the gauge is at 1/2 and the light comes on, you do have a groudn problem and your tank is running empty.
Believe the speedo cable goes over the mounting point otherwise it will get bent and cause trouble.
