The rubber boots are in bad shape and one has come separated the joint. All have bad cracking.
Is the replacement of these a job for a handyman/enthusiast or is it best left to the pros?
Any guidance / tricks?
Many thanks,
PeterCS
82 Baur
Need new Rubber on Rear output shafts
Re: Need new Rubber on Rear output shafts
you can get ones that split in half and you glue together = you can also get some that stretch over the top of the end and make life much easier.
