Fuel lines
Fuel lines
Hi, I'm going to replace the fuel pipes from the tank to the pump. Can anyone recommend where to get it from? Or if I should replace like for like, or use something else? The original looks like it aluminium.
Any advise would be great.
Cheers
Cheers
Re: Fuel lines
They are 8mm steel pipes, i've just replaced mine with 8mm copper pipe. Get a pipe bender is it's easy to kink this stuff.
You'll need to take your tanks off to do it, and don't forget to flare the ends so the rubber pipes can't slip off.
problemchild75
Re: Fuel lines
forgive my ignorance do you need to use steel, can you use the braided lines? need to do mine and add a return ;-(
Re: Fuel lines
Thanks Jacko. I might use copper myself. I've got some cheap bending and fairing tools. But I have been thinking of getting some braided stainless stuff. I don't know?!
Re: Fuel lines
I've just bought a new fuel pipe from BMW from the front to the back. Came pre shaped and wasnt to expensiver really.
- BMW-POWER
Re: Fuel lines
I have a complete set of 2 new oem bmw pipes, but im from belgium?
E10 2002tii 73'
E21 320/6 78' Anthrazitgrau
E30 325i 86' Diamantschwarz
E30 325iC 89' Diamantschwarz
E36 320iC 94' Dunkelblau
E87 118d 05' Havanna
Re: Fuel lines
whats the part number for these? My bmw dealer says that they are no longer available?!!?
Re: Fuel lines
Hi guys, I just ordered a set of of fuel lines from BMW. Probably not the cheapest way to do it!? I'll put up the part numbers in later. £45 for the 2 steel lines.
problemchild75
Re: Fuel lines
Hi guys, the part numbers are
B16.12.1.152.628
B16.12.1.118.994
I paid £46.48. I did ask for discount, the guy said he could as they had to come from Germany. Should be with in 5 days!
B16.12.1.152.628
B16.12.1.118.994
Reck
Re: Fuel lines
You should take some pics as you do it so we can get a photo tutorial up! Especially if you're replacing the fiddly bits behind the fuel tanks etc.
problemchild75
Re: Fuel lines
Dutch member Wondermike composed a nice grocery list a while ago for the entire operation. All hoses can be replaced rather easily using the cover under the rear seat and a garage jack. There's only one breather hose on top of the left side tank half that requires that half to be removed. Piece of cake though, only three bolts and the large connecting hose. Make sure it's empty though
Tank sender/pick up rubber O-ring 16121150391
Hose between filler and tank 16121176793
Connecting hose between tank halfs 16121176795
Breather hose to breather tank 134cm 16121177553
Breather hose left side tank 1 meter 16121176440 *
Y-connector breather hoses 16121115537
Hose pick up to fuel pump 1 meter 16121176440*
Fuel hose 8mm 1 meter 16121180409
* 16121176440 used on different places, a total of 2 metres is sufficient.
Hose between breather tank and blue overflow hose 6mm 13311272750
(also use abt 7cm between plastic line and steel line above right tank.
I personally left the breather hose from the breather tank to the filler to retain original looks in the trunk, that hose is also less prone to wear anyway.
Hose clamps:
18-24mm (4 X) 07129952109
15-19mm (8 X) 07129952107
09-12mm (5 X) 07129952102
42-48mm (2 X) 07129952119
37-43mm (2 X) 07129952117
12-15mm (6 X) 07129952104
And last one for now are the rubber bushes used for the fuel pump (etc) brackets: (3 X) 16121177891
Check lines between the pump, pressure regulator and fuel filter as well. How old is your fuel filter anyway?
Hose clamps:
