Please I'm looking for advice, I got my E21 running after I've bought it disassembled, but it's idling and running quite rough - (uneven revs, stalling..)
upon investigation I've found that it's ''spitting'' fuel out of jets(looking down the carb) - even when you rev it and hold higher revs you can clearly see that it is not ''spraying'' the fuel evenly, but in bursts, making the engine quite
There is a simple homemade ''T'' piece in place of the valve between mech. fuel pump and the carb(for return to tank), I suspect the return is small, forcing the needle valve open and making this mess...sooo the question is, what are you running in place of the regulator , or is there any aftermarket return valve to mount in place of this ''tee'' I have ?? sorry I dont have a pic handy, but I hope you can understand what I mean
Thanks a lot !!
Btw car is a 318, with solex carb
