temp & tacho
harleytrike
temp & tacho
Post by harleytrike »
my temp gauge and tacho have stopped working checked all the fuses and replaced them any ideas
Re: temp & tacho
Focus on fuse 14, does it have 12V? Reverse lights working? Also see http://www.bmwe21.net/?page_id=130
harleytrike
Re: temp & tacho
fuel gauge is still working and reversing lights still working
Re: temp & tacho
Weird!
harleytrike
Re: temp & tacho
that helps lol
cobbler2u
My E21(s): 323i baur
323i special
328 sport
325i
Re: temp & tacho
Post by cobbler2u »
Try another set of clocks.
Takes about 5 mins to change add will show if clocks are ok or not
Goodluck
harleytrike
Re: temp & tacho
clocks are perfect but tried another set still nothing
Re: temp & tacho
Id change the whole binacle rather than just the rev gauge.
harleytrike
Re: temp & tacho
whole binacle was changed but still nothing
Re: temp & tacho
Can you post pics of both binacle rear circuits?
Re: temp & tacho
If you take the under dash panel off. At the back on the right hand side there is an earth point. See if the screw holding it down is loose?
Re: temp & tacho
Also have you made sure you plugged everything back in the right place?
harleytrike
Re: temp & tacho
only unplugged the idle control and air flow meter also get ignition but car wont start then i wait a while and it starts
Re: temp & tacho
you might want to clean the plug that goes from the engine to the fuse box.
