temp
cobbler2u
My E21(s): 323i baur
323i special
328 sport
325i
temp
Post by cobbler2u »
baur is running sweet.
only prob is tempiture goes pass 1/2 way mark. Useally stays bang on in middle no matter how far i go.
Is it worth trying new thermostat
Re: temp
How far past the center mark? If its just 1-2mm I wouldn't bother but when she moves towards three quarters there might be issues, but that could be many things depending on the situation (at idle, during driving, etc.). More info in the FAQ section.
Re: temp
if you have a mulitmeter then you can use the below table
in my experience every e21 gauge is different..
Coolant temp (F) Gauge sensor (ohms)
186 64
166 73
161 87
145 126
137 143
122 200
107 267
99 309
89 367
81 440
cookster
My E21(s): 1983 323i Auto Kashmir
Re: temp
Post by cookster »
if it gets to 3/4 change the thermostat.
not that cheap, but cheaper than a new head.
e21 323i Kashmir Gold build date 1982 - original spec all round - Australian delivered/registered in 1983
Re: temp
check and change the temp sensor too - they die after a while and are only a few quid.
Re: temp
Agree with both!
cobbler2u
323i special
328 sport
325i
Re: temp
Post by cobbler2u »
Will do chaps
