Basically, I'm wondering if it would work if I just trim the swaybar back closer to the existing mounts, and reinforce the mounting points and fit beefier mounts, using the original swaybar only as a control arm; or if I'm better to beef up the mount points and then make a new custom pair of control arms with rose joints to mount in place of the sway bar? If I did this, do you think I would need to try and weld a washer to the ends of the remainder to stop them being able to pull clear out of the mounts under load? I think the angles they mount at would retain them ok but it's entirely probable that the design also took into account the swaybar being in a single piece.
I've seen the VAC kits etc but keep in mind this is a low (or as near as NO) budget build. I'm using scrap and parts I've salvaged from other vehicles so might be able to make the swaybar from the rear of a falcon mount to the front of the E21 somehow... Time will tell if I actually need a front swaybar for drift use anyway I guess.
