316 Headlamp
Sean
My E21(s): 1981 323i Auto
316 Headlamp
Post by Sean »
Guys,
My Headlight on my 316 blew. Went and got a replacement for it but it does not seem to fit. I can't remember the model number nbut i know for sure it is the right one. DO you have to modify the metal surrounding the lamp or what? It is a single headlight setup.
Thanks in advance.
polov8
Re: 316 Headlamp
Post by polov8 »
Are the single lamp units the same as mk1 golf?
Andy
Mihajlo
My E21(s): 1982 315swap323i
Re: 316 Headlamp
Post by Mihajlo »
No. But it can be modified to fit.
Diameter of the lamps are the same. Lamp suports must be modified.
Sean
Re: 316 Headlamp
Post by Sean »
okay but what about the lightbulb any takers?
polov8
Re: 316 Headlamp
Post by polov8 »
Not sure I get your question? But the E21 and mk1 golf both use an H4 bulb
Andy
Mihajlo
Re: 316 Headlamp
Post by Mihajlo »
bulb is the same H4 unit
Reck
Re: 316 Headlamp
Post by Reck »
Push and twist. Might need to be quite forceful!
Sean
Re: 316 Headlamp
Post by Sean »
Okay, I had the wrong bulb to hand.
Anyone had any joy with with Osram Silverstars>?
http://www.carbulbsdirect.com/product/o ... -two-bulbs
