4.0L E21 Build
SileNceR
Re: My 3yr+ E21 Build
Post by SileNceR »
http://www.e21build.com/2013/08/power-steering.html
Finally have power steering lines!
SileNceR
Post by SileNceR »
http://www.e21build.com/2013/09/injector-change.html
Changed the injectors so I could test the power steering and alternator charge properly - great news - it all works as it should!
Next stop - radiator hoses and thermofan!
Then I have to sort out power to this garage so I can do some more welding related jobs - primarily seat rails (both driver and passenger side), clutch pedal throw stop and retainer spring mounts, and driveshaft center bearing mounts.
SileNceR
Post by SileNceR »
http://www.e21build.com/2013/09/cooling-part-1.html
Started sorting out some cooling hoses/hose paths etc.
SileNceR
Post by SileNceR »
http://www.e21build.com/2013/09/cooling-part-2.html
More of the cooling sorted.
I am 90% certain I'm going to re-do the radiator support with a proper frame.
SileNceR
Post by SileNceR »
SileNceR
Post by SileNceR »
Quite some updates recently, and looks like a rigid structure, for the front shock towers, or?
SileNceR
Post by SileNceR »
To replace the radiator support. Because I've cut most of the original metal away and what's left keeps getting in my way.
You're right, you mentioned the support, my bad!
SileNceR
Post by SileNceR »
I think I will make one for the shock towers as well though. Can't hurt.
pandemonium001
My E21(s): E12 535i T (ish)
Post by pandemonium001 »
That looks nice and beefy! you might as well do a flip front now??
SileNceR
Post by SileNceR »
I'm not sure if I've still got all the bits for a flip front. How do people find actually working on the flip front cars? It's always seemed (to me) like it would be difficult to get around things like belts with the flip front.
SileNceR
Post by SileNceR »
:thumbsup
SileNceR
Post by SileNceR »
