Can someone identify this g/box?
g60go
Post by g60go »
Got a 5spd box i wonder if someone can identify exactly which one it is? Ive looked at the info on here but it doesnt seem to match any! Have a look at the pics!
part number
3x bolt flange
reverse switch on top
this ones a bit fuzzy!
Re: Can someone identify this g/box?
Looks like a 5 speed at least, and it has a speedo drive. If it says M60 at the housing on the side the clutch slave is mounted its a M20 gearbox, otherwise M10
g60go
Post by g60go »
Yes its got M60 written on the side too! And yes its 5spd! `Believed` to have came from an 82 323i to convert mine (an auto!) but i never removed it and didnt know the car(although i briefly seen the car it was removed from!)Can u identify what it is from the numbers?
g60go
Post by g60go »
OK,after further investigation on this site and comparing some pics,it seems to be a 5spd economy box,does this sound right? Just wanted to 100% identify it as im thinking of selling my E21 and all the parts so i needed to be sure what it was!
Yup, it most likely is. Most doglegs have the Reverse light switch on the rear of the box. Also see the FAQ section for more info: http://www.bmwe21.net/forum/viewtopic.php?f=38&t=13418
yep that's an ordinary m20 5 speed.
