Steeringrack solid mounts
I've recently been looking at the massive amount of play in my steering rack. New bushes are needed. Just wondering if there will be any side effects to have it solid mounted to the same points its connected to now. Is there a reason they are rubber mounted? I know polybushes are a lot better than oem. But I can't find a UK supplier. It won't cost me much in design/make, was thinking something on the lines of the picture below. But to fit the e21 rack on the existing mounting. Any help would be great.
Re: Steeringrack solid mounts
Go for it, make me some too. All BMWs after the E21 were bolted direct to the front subframe.
I'll put together a prototype and if it works I'll let you all know.
if there are other people interested in this let me know and I'll keep you informed.
I would be interested also
Ben
Ben
I'd be interested too.
- JTY
- My E21(s): 1981 323i
Yes, +1 here too!
- JTY
Any update?
Update:
Just got my car back from garage so it's now moted. I've got some 3d models on computer sorted just gotta measure it out properly. Then I'll get a set or two made and make sure there going to be ok.
Cheers
Cheers
- e21-Mark
I got my poly bushes from the USA but, because they sent them in a bloody big box and there was import duty, they ended up being way overpriced.
Do you, or anyone else, have the mount/bush dimensions?
I don't have the dimensions but will in a few days. The inside is just a straight bore but the outside is an odd shape that might not be able to reproduce unless you have the standard bushes unmolestered.
- e21-Mark
Spoke to Supaflex and they're pretty confident that one of the hundreds of bushes they do will fit. It's certainly worth giving them the dimensions anyway.
No worries. I'll see if I can sort the sizes out this week.
+1 here as well
harleytrike
pandemonium001
- My E21(s): E12 535i T (ish)
me as well please.
