E21 Swap
Mohanad Hani
My E21(s): 315 1979
E21 Swap
Post by Mohanad Hani »
Hey all
I am mohanad hani from egypt. i wanted to ask u some questions.
because i decided to make an engine swap to my E21 i wanted to know what is the engine that i can fit in easily without any modification ??
Re: E21 Swap
An e30 m20/2.5 but you need a 320/323 subframe and dual pipe sender unit for the added fuel line. (assuming your car is a 316)
Mohanad Hani
My E21(s): 315 1979
Re: E21 Swap
i don't want to get a subframe i want to just remove the old and install the new. what do you think about an M40B18 ?
and what's better than that ?
Re: E21 Swap
It won't fit unless you modify your subframe.
Re: E21 Swap
M40 doesn't bring much extra I guess. How about M42 with custom engine mounts?
Mohanad Hani
My E21(s): 315 1979
Re: E21 Swap
i want to easily fit an engine guys. M42 must make a modification and i don't like doing that cause it's never made safely here in egypt
Re: E21 Swap
Then there's only one option, modify your M10...
Mohanad Hani
My E21(s): 315 1979
Re: E21 Swap
ok thanks alot guys for helping.
so the easiest engine to be easily installed is the M20 then the M42 ?
trash-berd
My E21(s): '82 320i US Manual 1.8L
Facebook page: https://www.facebook.com/eli.tripi.5
Re: E21 Swap
Post by trash-berd »
M20 still requires a new subframe, there's a thread around here somewhere that has pictures comparing the two, showing the differences. M10's aren't bad engines, and if you do it right it'll still be a blast to drive.
Mohanad Hani
My E21(s): 315 1979
Re: E21 Swap
what do you think about an M20B20 ? is it good and doesn't have much proplems and have good fuel efficeny ?
Re: E21 Swap
Nope, power isn't much more that from your current engine, fuel economy isn't all that and you need a matching E21 M20 gearbox to get the speedometer to work. My suggestions: tune that M10 or if you really want to modify the subframe and if you can source an E21 M20 gearbox go for a M20B25 or M50B25. Cheap to buy, powerful and fuel efficient, but it will be more of a project.
Re: E21 Swap
I would also turbo the m10.
Mohanad Hani
My E21(s): 315 1979
Re: E21 Swap
my M10 died :S now i must go for a swap. M20B20 or M40B16/18 ?!
Re: E21 Swap
Get another m10?
Mihajlo
My E21(s): 1982 315swap323i
Re: E21 Swap
Post by Mihajlo »
M10 + turbo. :mrgreen:
