hi there,
i am rebuilding my e21 2.0 6 cyl carb here comes the good part now the previous owner ''gently'' removed the fuse box and wiring loom by ripping some of the wires out of the connection block inside the fuse box and some more wires does anybody has some photos of this big white block and the fusebox on the inside so i can see what wire goes where
i hope you guys can help thnx
i need some pictures please
Re: i need some pictures please
you can tell because there are colour coded card inside the fuse box. you can see which colour wires go where
yes but there are still some wires that are unclear to me and i would like to play safe not really fond of fire
i used to have a pic cant find it now :/
show us a pic of how far you have got with your fuse box.
big white funny box connector goes opposite side of the fuse box where the big red wire goes, you cant plug it in unless its on the correct terminals. there is a smaller white connector that goes to your lights, the rest of your loose wires go towards the top of the fuse box. i hope this helps you lol.
thnx for thhe reply, the white connector thing is the main problem out of that block some wires are riped out so thats why i need some pictures
and for the placing of some of the relai wires etc
e21 316 (1981) TRE702X.
thank you very much this is perfect!
''topic close''
