handbrake cable renewal?
gazzab1978
My E21(s): 320 baur
Post by gazzab1978 »
hi, i need to change one of my handbrake cables for the mot but im struggling to get it off the car. i have pulled the cable out of the drum but it seems that where it goes down the transmission tunnel the cable has a metal outer sleeve which seems to be welded to the trans tunnel. is the new cable suppose to go in the metal sleeve?
drjim
Re: handbrake cable renewal?
Post by drjim »
There's a metal tube welded to the car. Cable runs inside that, has a plastic thing on the end that plugs the end of the tube up. Have you unfastened the lever end, should pull out easily.
1982 Saphirblau Baur 325i
Cars all gone!
gazzab1978
My E21(s): 320 baur
yeah i have undone the lever end but didnt want to break something by pulling it. ill give it another go tomorrow.
cheers
get some vice clips on the metal end that meets the tube going through the body and twist it round a few times.
Eddie.
My E21(s): [O==[][]==O]
Post by Eddie. »
I'm doing this tonight myself, any extra tips or tricks?
Twist the bit that is going into the tube itll come out
