e21 project
e21 project
Hi this is my new e21 complete with doner car. bought from Ian (e21.net member)
http://s1280.photobucket.com/user/tanve ... ibrary/e21
please stay tuned and all comments welcome. Wish us luck.
Re: e21 project
Nice, keep us posted sir! OK to move this thread to the 6 cil topic, or do you have bigger plans for the car?
Re: e21 project
plans so far are to restore the car back to original factory condition and add a few small touches just to make her look, sound and go sweet.
- davidvincent
- My E21(s): 1982 320/6 Lapis Blau
Re: e21 project
What's the interior like? think I only saw photos of the donor car?
Great licence plate
Great licence plate
Re: e21 project
are you selling parts from the donor car?
Re: e21 project
The interior is pacific blue its in good condition for the age of the car, no rips or tears, the head lining could do with some tlc. someone told me its easy to change for a new one, but when I was taking the one out from the donor car it just ripped and broke. ill take some interior pictures tomorrow.davidvincent wrote:What's the interior like? think I only saw photos of the donor car?
Great licence plate
I am selling some things which I definitely know I am not going to be using for mine, like the seats, I still have lots of things to sort through but as soon as I have it all sorted then yes every spare part will be up for grabs.G_e21 wrote:are you selling parts from the donor car?
Re: e21 project
So the donor car has all been stripped and gone. The real (expensive) work is starting to begin.
Firstly stripping it back to see what needs repairing. so we checked the usual suspects, boot floor had plates welded over these holes. just a quick fix job really so the plates have been grinded off.
next up was the sills. Drivers side was surprisingly clean.
I noticed that the kick plate is missing along with the holes so I think this sill has already been replaced before.
passenger side
Im guessing the welding on the sill was done the same time as the boot. I got 2 new sills so they will both be replaced once the boot is done.
the replacement boot floor getting prepped for the towing hook to be refitted.
passenger side
Re: e21 project
here's some interior shots.
- davidvincent
Re: e21 project
The body work photos seem to be missing..... interior looks nice though
Re: e21 project
just a quick update....
The drain holes have been replaced with the ones that got cut out from the other car. A bit of a tedious job as we decided to do some of the welding ourselves to keep the costs down, we got a gasless mig welder but we should have got the gas one as the metal keeps buckling with the heat and the weld doesn't come up as nice as it does with a gas welder. So my dad tells me,
But after some welding, grinding, re welding, manipulation and grinding, we kind of got it looking like it should.
here we are in the process of getting the spare wheel section done.
As you can see this still needs re welding, and we lost some of the shape where the plate got welded in for the rear hook, I think we are going to have another go to try and get the curve as original as possible, or ask the garage to do it when it goes in for spray. Also the plug hole has some rust but the plan is to weld the plug in place.
again, there was a small hole in this area, also where the metal is so thin it makes it difficult to weld and try not to burn through. also trying not to disturb the metal where the ridges are trying to keep the shape and look original.
next we have these 2 areas left to weld in the boot. I really cant wait until the welding is finished. We haven't even taken out the carpets yet. only god knows what lies underneath.
Re: e21 project
small update not much going on...car has been booked in with an auto welder for mid November so hopefully the wheels will be in motion then.
The spare wheel section is done, just need to stick the plugs back in but no rush...
some other projects we got going on are slowly moving too. I know its not E21 but just thought some of you might like to see.
