Don't have the space to do this, sorry.nas80 wrote:17mm nuts x4 holding the diff on
6 bolts each driveshaft
4 17mm nuts connecting the prop to diff.
19mm nut and bolt for the rear diff hanger mount
If you can undo and tighten a bunch of bolts up then I cannot see how you could possibly fail.
Obviously make sure you seal and tighten the diff rear cover and put the right oil in it.
I am not THAT scared
besides, almost everything is written(or can be found) in here,
Will ask my mechanic to do this
