I picked up a half completed project a few months back.http://www.bmwe21.net/forum/viewtopic.php?f=2&t=22387 I've been slowly collecting parts and putting it back together. The car should have a mechanical fuel pump but there is no provision for it on the block. The engine has been rebuild and i believe an ETA block may have been used. Any way to identify what block i may have ? Also if anyone can supply a diagram or explaination of the fuel line routing, i would greatly appreciate it. My son took the fuel tanks out so we could have them cleaned and tested, unfortunately i was unable to get under the car at the time due to knee surgery. The tanks are now back in and i have no idea of the fuel line routing. Thanks.
BTW. It's a 79 320/6 with solex 4A1 carb.
320/6 missing fuel pump ?
Re: 320/6 missing fuel pump ?
You'lll need the 323i fuelline route.
Newer B20's do not have the mechanical fuel pump option, since all later B20's are fuel injected. There will be 2 fuel lines available on your shell, one feed and one return.
So you will need a high pressure electric fuel pump and filter assembly.
Thanks for the reply. That's kinda what I thought. From what I've researched its best to locate the pump near the fuel tank. Anyone have any recommendation on what pump to use ? What psi should I be looking for ? Could I use an in tank pump from an e30 ? Thanks.
- Jason_323i
You need a e30 318is pump assembly with a minor mod to shorten the fuel pump supply leg
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
Thanks for the reply. That was one of the solutions I have found. Should be easy enough to source too.
