Little by little with 320i 1/77
Re: Little by little with 320i 1/77
Post by 3771489 »
Still under construction. :| All pics moved here. http://basso72.1g.fi/kuvat/e21+320i+VESseli/
78 beemergal
Post by 78 beemergal »
Thank you I can finally access the link to see the photos - great work. I am out of the states - California to be precise and wish I knew someone with your abilities here. I have a 78 320i automatic and it has some rust that needs to be worked on but most bodyshops here just throw a bunch of bondo on the vehicle only for the rust to return down the line. Thanks again for the opportunity to see the job done proper.
78 beemergal
johne21
Post by johne21 »
Top class work - is this mechanical fuel injection?
1976 e21 320i A4 Alpina #1755
3771489
Post by 3771489 »
johne21 wrote:Top class work - is this mechanical fuel injection?
Original K-jet.
78 beemergal wrote:Thank you I can finally access the link to see the photos - great work. I am out of the states - California to be precise and wish I knew someone with your abilities here. I have a 78 320i automatic and it has some rust that needs to be worked on but most bodyshops here just throw a bunch of bondo on the vehicle only for the rust to return down the line. Thanks again for the opportunity to see the job done proper.
78 beemergal
Hiya, well yeah sadly that's how we know US restorations but surely there must be some fanatic out there? How about these guys in the larger LA area, they know their 02's and E21's! http://www.2002ad.com/
Post by 3771489 »
Some pics...
All clean stuff, me like!
arshad76
Post by arshad76 »
Was going to say the same as Jeroen, nice neat work there!
UK Moderator
3771489
Post by 3771489 »
Not much happened but sometimes little progress..
Not bad! I see you're going for the shifter lock as well, I installed it in my E21 as well.
Beautiful. Nice work. :thumbsup
LeeLee
My E21(s): E21 316 1981
Post by LeeLee »
What did you use to underseal??
inspirationally clean good job!!
M15KYY
Post by M15KYY »
reminds me of when i did my kashmir gold 316, stunning work pal and great attention to detail. love it
E21 316 M60
3771489
Post by 3771489 »
Jeroen wrote:Not bad! I see you're going for the shifter lock as well, I installed it in my E21 as well.
Yes,it's pretty rare "original zübehör" and fit nice behind new 5-speed Getrag 240...
3771489
Post by 3771489 »
LeeLee wrote:What did you use to underseal??
2K Epoxy
Then,I thought it was Dinitrol 445 (or some similar) http://www.rust.co.uk/012-dinitrol-445- ... p/p497377/
And last,black 2k PU-paint.
