And also... what is this? the little metal C bar thing....
I wash the grills thoroughly with fairy liquid then I sand the grills with a medium grade sand paper (what ever is at hand) very carefully. Wash again, let it dry, then wipe them down with paint prep wipes. The wipes left little bits of material everywhere so i wouldnt advise to use them, id use a cloth and some sort of degreaser for paint prep. then i spray the grills with 3-5 coats of satin black paint. After being left near my boiler for 3 days to dry and harden, they are ready to go onto the car. Sanding takes around 2 hours to properly reach all areas. then cleaning another 20-30 mins. Sanding is the killer part, kills your fingers.Jeroen wrote:How did you treat the grills?
No primer, it wasnt an issue on my E30 and E21, hoping it lasts on the E28. thanks bro.uwbuurman wrote:Didn't use plastic primer? They look great!
Iv been tackling small issues, still have the cluster left to change over and sort out the electric windows. At the moment im wrestling with an overheating issue, have no idea whats causing it, may have to pull out the heater matrix. i flushed the system, no blockages, fan is working, no leaks, water pump seems to be working. a little lost to be honest.Jeroen wrote:Not bad! Any progress with the gremlins? Overlooked a post or two, happy to help you out with any remaining issues if I can!
