Brake distributor = Master Cylinder ?? Is it the same?
petroscf
My E21(s): '77 EU 316 manual
Post by petroscf »
What might exactly be the "brake distributor" as my mechanic called the part?
Could it be the Master Cylinder?
It seems that this Brake Distributor part is leaking on my car, and I can't find it from BMW here in Greece, so I would have to look for it elsewhere
Any suggestions on this part... Where should I look for it? W&N ?
/oo=00=oo\
E21 Forever
Re: Brake distributor = Master Cylinder ?? Is it the same?
I think indeed it is the master brake cylinder.
petroscf
Post by petroscf »
Any suggestions on the part?
W&N have it but I hear various things about them, although up to now I haven't had any problems with them
/oo=00=oo\
E21 Forever
E21noob
My E21(s): SOLD
Post by E21noob »
I think what you need is a repair kit: part number 34311156133.
I havent done it myself though..
petroscf
Post by petroscf »
Mechanic says he prefers the full part
I don't know why, I'll have a check if I find the time later to pass by and have a look, but anyway, the prices in W&N of the two parts, as I see, is almost the same (99 euros the full cylinder, and 95 for the repair kit - or do I need to buy both? does the master cylinder come empty or something?)
/oo=00=oo\
E21 Forever
If WN provides a decent brand like Até (which is OEM) then you can just order a new unit for 99 Euros then, that is a complete and assembled unit.
petroscf
Post by petroscf »
It finally was the pressure regulator, and not the master cylinder
These differences in names from English to Greek is what makes things difficult..
/oo=00=oo\
E21 Forever
So that's the thing mounted at the inner wing which regultates the brake pressure between front and rear?
petroscf
Post by petroscf »
Mounted on the inner wing yes. Just under the servo (if that's how it's called)
Distributing between fron and rear? Don't know, however, probably yes, it has 4 pipes connencted on it, and the models after 1979 have only three - if that's of any help
/oo=00=oo\
E21 Forever
petroscf
Post by petroscf »
34331116365
/oo=00=oo\
E21 Forever
petroscf
Post by petroscf »
And here's a pic:
/oo=00=oo\
E21 Forever
