pandemonium001
My E21(s): E12 535i T (ish)
Post by pandemonium001 »
Duracel79 wrote:I'm pretty sure all the panels are either spot welded or welded proper.
Looks like the only glue used is seam sealer over the joints.
They have done 2002's, E9's, E30's and they all strip fine so fingers crossed.
Ben
The rear quarters are deffo spot welded to the inner outer wheel tub. It just looks like they are glued, they are so close on the inside BMW ran a bead of seam sealer across the full length of the rear arch, i only presume to stop them vibrating together.
cant wait to see the post dip picture's, something I could never afford. :thumbsup
Awesome.. Did it come back ok or full of holes?
The problem sits within the c pillar. There are two panels that are only glued, aswell as the (Whats it called) little box were you fill up the tank, where the fillerneck starts. Within the c pillar you cant get to it, without opening it up. Side panels are spotwelded ofcourse. I can lay out the complete spotwelded places for you if you need that
Duracel79
Post by Duracel79 »
nas80 wrote:Awesome.. Did it come back ok or full of holes?
Still a few weeks away mate, pickup is end of March. I'll update with pics then
Duracel79
Post by Duracel79 »
uwbuurman wrote:The problem sits within the c pillar. There are two panels that are only glued, aswell as the (Whats it called) little box were you fill up the tank, where the fillerneck starts. Within the c pillar you cant get to it, without opening it up. Side panels are spotwelded ofcourse. I can lay out the complete spotwelded places for you if you need that
Hi uwbuurman,
I think I know where you mean, I guess for originality/concours then these glued areas are important.
For mine a fully welded cage is going in so its less of an issue.
Cage will be tied into the A and B pillars with gussets.
And tied into the front and rear turrets, the diff mountings and the transmission tunnel.
Cheers
Ben
who is doing your cage Ben?
Duracel79
Post by Duracel79 »
nas80 wrote:who is doing your cage Ben?
Custom Cages at Daventry:
http://www.customcages.co.uk/homepage
They list the cage for an E21, but I'm adding a few more options.
Ben
Mucka
My E21(s): 320
Post by Mucka »
The customcages are awesome bits of work
could you let me know what costs are? I need to get the exact same thing.
Duracel79
Post by Duracel79 »
Some update pics of the shell after being dipped de-rust and passivated, it is interesting to see the amount of brazing used between some of the panels:
Lots more pics can be found in the Photobucket album, may be useful to see how all the panels are joined in the factory:
http://s180.photobucket.com/user/durace ... E21?sort=3
Regards
Ben
Duracel79
Post by Duracel79 »
Got some new parts:
Doors and Roof Hoop:
Pedal box setup:
Also made a start removing the sunroof cage and welding in the roof panel:
Regards
Ben
Viewed all 276 pics. Looks great, some spots and holes, but all on known places. Nothing out of the ordinary, so a great base to start from!
pandemonium001
Super clean, :thumbsup
I would love to repair and just clearcoat it as it is.
Lars-Nord
Post by Lars-Nord »
That looks great. Even i could have made that chassi good again. Love to follow the this tread. Good luck with it.
81 e21 323i polaris
Lars! great to see you here!
