My 83 316 E21 Project
Re: My 83 316 E21 Project
Haven't updated this in awhile , so here is some progress ill let the pictures do the talking
Got all the hardlines finished but not 100% happy so ill probably redo them but the same bends
Car on the ramp having the struts all welded up
Test fit with a 16 just to see how it would sit
Air all finished and on , it sits slightly rear ranked on the standard wheels , there is a reason for that after a lot of thought and measurements me and my friend luke who done the welding decided to do the rear struts as short as possible to be able to run a good psi at ride on the new 16s , it should sit slightly nose down on the new wheels
Managed to snap my exhaust so
instead of repairing it i decided to go for a full stainless system and centre box delete , as for tail pipe i wanted to keep it oem as possible so i went for the same tip but 1/2 bigger
Before
After
Next i borrowed a set of Rs's off a friend to work out the specs of my new wheels
I love the look of the Rs's but that is not the direction i want to go with this car , my new wheels will be slightly more aggressive poking 6mm more rear and 12mm more front and have 3.5 dish rear and 2.5 front 16x9 , 16x8.5 as for design for now all I'm saying is they're ccw's .
As for whats left to do , my wheels should show up the end of this week along with the tyres then its a test fit before i drop it off at the body shop for the arches to be rolled and a few touch ups , after that all i need to do it put some panels back in the interior and fit the head unit plus i want to give the car a full service
Managed to snap my exhaust so instead of repairing it i decided to go for a full stainless system and centre box delete , as for tail pipe i wanted to keep it oem as possible so i went for the same tip but 1/2 bigger
Before
After
Nicely done sir! Looking forward to the 'end' result on wheels!
pandemonium001
- My E21(s): E12 535i T (ish)
Loving it.
So jealous you get to start with the good bits, any info on the dampers and air bags, min max lengths and so on.
You should do a how to guide with specific sizes for the E21 in the technical section. Im sure there will be many questions on how to do this after people see your setup.
+1
This needs a how to thread
E36 328i Daily driver
E36 328i Touring
E36 328i Touring
paulalbion
- E21 starter
- My E21(s): 316 manual
Looks stunning!
What air ride set up have you purchased?
Only thing I'm gutted about with my E21 is not having a stereo at all so would need all completely wiring in which I just can not be bothered with doing lol
- raseeda green
Nice!
Like the way you've got it! Cheers
316 auto raseeda green
323 red m52 modified
