BB-Carworks 323 S-Edition restauration
Re: BB-Carworks 323 S-Edition restauration
That looks like some really good paint. Unfortunately it doesn't look like I can get it the U.S.
Are you spraying it or brushing it on?
- BuschBertl
- My E21(s): 323i S-Edition E21, 325i E30, M3 E46
Large areas spraying- small areas brushing. I always use Brantho - but i think there will be a good as Brantho in U.S ?!?Jeff323 wrote:That looks like some really good paint. Unfortunately it doesn't look like I can get it the U.S.Are you spraying it or brushing it on?
BB-Carworks
BMW E21 323i S-Edition 1982
BMW E30 325i Cabrio 1991
BMW F87N M2 Competition 2018
- BuschBertl
27.05.2015
Today i impregnate the seams with Owatrol Oil. This Oil has a good capable of creep and is dry after 24 hours. After that you can overpaint with base coat. In that case with Brantho!
Sorry for the bad pictures today - i forgot my Canon and so i used my iphone!
BB-Carworks
I'll have to do some research. I'm not finding any alternatives yet though. I just emailed the company to see if they can recommend an alternative available in the U.S. From what I'm reading about it, it looks like some really great stuff and better than the normal POR 15 and others we see over here in the U.S.BuschBertl wrote:Large areas spraying- small areas brushing. I always use Brantho - but i think there will be a good as Brantho in U.S ?!?Jeff323 wrote:That looks like some really good paint. Unfortunately it doesn't look like I can get it the U.S.Are you spraying it or brushing it on?
Hmm, Im not keen on Owatrol. I have some bad experiances with that and primer...
- BuschBertl
With Brantho primer there are no problemsuwbuurman wrote:Hmm, Im not keen on Owatrol. I have some bad experiances with that and primer...
BB-Carworks
- BuschBertl
Today i cleaned the surplus Owatrol an put on some primer
BB-Carworks
- BuschBertl
New suspensions installed
BB-Carworks
This looks like a tidy resto.
- BuschBertl
2015.08.13
Today i cut out the last pieces from the back chasis. Then i prepaired the new one.
BB-Carworks
