e21 m60V8 Drift project
M15KYY
Re: e21 m60V8 Drift project
Post by M15KYY »
;) looking good brother!! look near enough equal length too! building the equal flow manifolds on my m60 made it breathe so much better! keep up the good work and keep those pictures coming!
E21 316 M60
Adje
Post by Adje »
They are far from equal length. There was simply not enough space. I tried to make it as good as possible within the space.
It should be much better than the original log-style ones.
Adje
Post by Adje »
I have been working on the X-Pipe for a couple of evenings. Most people say it is the best to have it as close to the engine as possible.
Maybe this might be a little to close... But it was the only option to do it like this if i wanted to keep the left and right pipe equal length.
From this point a double pipe should go along the right hand side of the gearbox so i have no heat and space issues on the drivers side for the pedals e.t.c.
Adje
Post by Adje »
In the mean time i had a driveshaft made, and balanced by a specialist. The main part including the hardy disk is from the 740i donor car, made to a e34 constant velocity joint.
So now i could line up the gearbox, and build the support. The exhaust has to go under it.
first i made this:
but if i made brackets for it, it was not possible to lower the transmission (when removing)
so this was the solution:
:thumbsup :thumbsup
Adje
Post by Adje »
Adje
Post by Adje »
exhaust is almost finished.
Duracel79
Post by Duracel79 »
Good work, that should have a nice burble :thumbsup
Adje
Post by Adje »
exhaust is finished!
exhaust suspension at the rear axle:
added some V-bands so the mufflers can be removed, and to be able to mount the exhaust.
gaaf hoor!
Coming along quite nicely!
