You want more technical detail on each of these daily updates? Check out the blog I have started writing about this amongst other projects!
http://blog.garagistic.com
Ok, so here are the bullet points of the near term overhaul.
Intro: Start with bone stock 1980 E21 320i FI M10
- S54B32 101k miles from 2001 M3 w/ ZF S5D-320Z-HCH
- Complete E30 Rear Suspension with offset TA bushings and S3.46 Medium Case, rear disc
- Rota Slipstream 15x7.5 ET25 on Hankook 205/50-15
- Full GC Coilover 350/400 suspension
- 80A Poly bushings all around, new bearings, brakes.
- New Windshield
Here’s some history:
I bought this 300k mile E21 in February as my daily driver to/from work. I was getting 30+mpg for a while until I sprung an oil leak in July on my 50 mile commute home, no indication of lost oil pressure resulting in a blown connecting rod slip-slappin’ inside the case. So the motor was toast. What a better time to do a motor swap than now!? So I’ve spent the last 2 months collecting parts with Garagistic, planning schedule, and getting ready to tear into it. The time has now come.
Yes, this is as live as it gets with swaps and there’s a chance I won’t do it in 10 days.
Yes, the car was plasti-dipped when I got it. I plan to re-spray it next year.
Yes, There’s surface rust, but the rest of the car is solid (except under the driver pedals).
No, I don’t plan to issue a formal write-up about it, but will document here on the forums.
No, I won’t be answering every single question. Won’t have the time.
I plan to get the car running in 10 days. Next build post will be this Saturday, September 10th, after I get the car to the shop and start tear down!
Here are some pictures:
With that being said, I have some things to sell. The following parts to be picked up in Huntington Beach, CA....
Front Spindles, unmodified - $400
M10B18 - Blown Connecting Rod - $100
Getrag 240/245 - $200
Driveshaft Complete - $100
Exhaust - $100
Complete Rear End with modified TA’s (Shock mount cut off), half shafts (no diff) - $150
Differential 3.91 Open Small Case - $200
The following I WILL ship:
AC Lines - ($30)
Front Set Headlights w/ Side Grills - $150
Parking Brake Pads Brand New - $25
Front Shocks Offbrand Brand new - $120
Front Shocks Used Bilstein - $100
Rear Seat Tan - $100
Rear Door Panels - $20
So there you have it. Daily updates posted around 10pm EST and with Garagistic’s help, I am sure we can do this, so stay tuned!
Thanks, Garagistic Team, for making this a reality!!!!
