E9 3.0csi Restoration - Duracel79
Duracel79
Re: E9 3.0csi Restoration - Duracel79
Post by Duracel79 »
The non jacking pads for shell painting, which include the fuel pipe protection guard:
Great!!! I cut out those big round holes to fit the original caps in the center of the floorboards. This looks ok, but original is better looking ;-) car won't see any snow or rain again, so it shouldn't be a problem.
What tool do you use to bend that sheetmetal?
Duracel79
Post by Duracel79 »
uwbuurman wrote:Great!!! I cut out those big round holes to fit the original caps in the center of the floorboards. This looks ok, but original is better looking ;-) car won't see any snow or rain again, so it shouldn't be a problem.
Yes we will be cutting out the holes to fit the floor plugs, the holes are needed for draining during dip-coating.
As for tools, mostly normal hand tools, vices, lengths of bar stock (round / box section etc) etc.
lemonayd
Post by lemonayd »
WOW what a mammoth build so glad i found this can't wait for the next instalment
thE E9 is my fav of all time, great work Ben
atb Ayds
www.pristinebodyworks.co.uk
croma_man
My E21(s): '83 EU 327i
Post by croma_man »
my friend had the same experience with his E9, car looked normal when he bought it in italy, then...all hell went loose when he started to chisel the filler from the car.
hats off sir !
TopCat
My E21(s): 1980 Alpina B6 2.8
Post by TopCat »
These E9s and to a lesser exetnt the 2002s are now becoming rare and valuable enough to restore- why doesn't someone make the entire body - as they do for Jeeps:
http://mdjuan.com.ph/civilian/?model=cj7
and you can even buy an entire Camaro bodyshell:
http://dynacornbodies.com/body-shells/camaro/
ps Wish Dynacorn could make an E9 bodyshell for you!
Regards
Topcat
Isle of Man Inverness
1980 BMW E21 Alpina B6 2.8
1991 BMW E30 Hartge H26
Hmmmm nothing you see for any BMW huh?
TopCat
Post by TopCat »
not yet- but perhaps someone should contact them?
Regards
Topcat
Duracel79
Post by Duracel79 »
Sorry its been a little while, still been busy working away.
Trial fitted the pedal box to get the throttle pedal position and welded the mount in:
Started work on the strut tops, first we made a brace to retain the location:
The cracked on with removing the bad metal to see what was needed, I was a bit slack with taking photos so things may jump about a bit:
After that was all back together we removed the whole front panel to replace the splash guards and do lots more repairs on the front panel:
Cheers
Ben
Duracel79
Post by Duracel79 »
Well, just realised we missed taking pics of quite a bit (was busy with the E21 - must update that as well).
The front panel went back on and we repaired the front wings before getting them back on.
First pic was a coffee break before the second wing went on:
We also went round the rest of the shell fixing bits and bobs like this extra hole in the rear panel:
Cheers
Ben
Pretty drastic steps, but this e9 is already much better than when you started! Keep up this great work!!
What a lot of work you already have done.
Nice progress Ben!!!
Mihajlo
My E21(s): 1982 315swap323i
Post by Mihajlo »
F... rust :(
You don't know how much you have to cut off until you start scratching... And there is more and more and MORE of it.. :(
Nice to see you know the job and you are not afraid of do it as it should be done.
I'm looking forward to see it back on the wheels and with 0% of rust on it.
lemonayd
Post by lemonayd »
legends :cheers :cheers
looking forward to you nx instalments...
atb Ayds :boogie :boogie
