M10 crank pulley with trigger teeth - best source??
Mark3
My E21(s): 1983 RHD 1.6 manual
Post by Mark3 »
I am getting ready to fit throttle bodies to my M10 and have everything except a crank trigger pulley which has the teeth for the crank position sensor.
I have done some googling and found '02 Again' have one for $229 + shipping from the US, and there is a guy in Norway who will make one for £550!!
Are these the only options other than attaching (welding?) a crank trigger ring to my existing pulley? I am doubtful that this approach will see the trigger ring run true, and this is critical as the sensor has to be very close.
Do the crank pulleys from M40/M42 fit? What about M20?
What is the M10 pulley made from - is it mild steel?
Thanks,
Mark
E21-driver
My E21(s): BMW E21 315
Re: M10 crank pulley with trigger teeth - best source??
Post by E21-driver »
As far as I remember, Ireland Engineering had one for the M10. And no, the others don't fit. And yes, the M10 is made from steel, but not mild.
1982 315 reseda
Mark3
Post by Mark3 »
E21-driver wrote:As far as I remember, Ireland Engineering had one for the M10. And no, the others don't fit. And yes, the M10 is made from steel, but not mild.
Thanks,
I couldn't see one on their website so I'll drop them an email.
Do you know what grade the steel is - one option is to weld a stainless gear ring onto the pulley
You can cut it yourself at every shop with a water or laser cutter. I have description posted here:
http://bmwe21.net/forum/viewtopic.php?f ... 15#p289562
