Inspired my marks tango I have tried to stick all my upgrades into one post
First the dashboard mods
Hi
Here are some pictures of my dash board modifications, I stripped down a dash to fit some gauges I picked up of eBay, using the original dash for the gauges I made a couple of alloy spacer rings for the tach and speedo and glued them to the dash.
The I used a hole cutter to open out the existing gauge locations for the water temp and oil pressure. Above these gauges I have fitted warning lights for low oil pressure & high water temp. I used cut down mounting ring that came with the LED’s and glued them to the dash.
It’s not finished yet I have to add the module for the indicators high beam etc and spray the dash matt black.
Next new coilovers and top mounts (rear rates are a bit soft)
Hi
I eventually got my LEDA coilovers rebuilt by GAZ, but from what I can see the only orginal bit is the bottom of the front strut housing.
Rebound & Bump Control
61mm front housing
nickel coating
alloy components are anodised
Spring Rates and valving specific for the track (400 front 225 rear)
followed by body work
Well here is a picture of my car getting the body work sorted (note the grp bonnet 7 16X7.5 hartge rims) on the outside the rubbing strips have been removed and the holes welded up.
Patch to rear arch
Drivers floor repair
Passenger floor repair
Welded in seat riais
repair to rear quarter
Divers side seat
and for DrJim the passenger B post
Got the car back from welding
Next was the work on the cage
The cage is going in the car and here are a few pictures so far
A bit of an update
A quick update of my e21 the cage is done
Then work on the frotn brakes (Now needs to be redone for 5 stud)
Ended up going with a set of used wilwoods I got cheap, just clear the Oz pina copies
The rear fuel tank
One of mick spoiler combo's
Some Pro car type mirrors
