My 323i Race Car Update
Duracel79
Post by Duracel79 »
Well,
I've been sorting out my spare differential to replace the one in the car.
For now a standard 3.45:1 BMW LSD with standard lockup. Had my transmission man check it all over and set up the backlash etc.
Today I removed the diff from the car that I felt was suspect. It is an 3.45:1 LSD but with both wheels jacked up the wheels didn't turn the same direction unless using very small pressure.
I took it all apart and what did I find but a Quaife LSD!! :shock:
Now that was a surprise find. 8)
These run without plates, just gears so do not feel the same. the standard lsd test doesn't work with them.
Oh well I think i'll use the standard BMW unit for now and build the Quaife into a diff with lower ratio's.
Duracel79
tommi_e21
Post by tommi_e21 »
how much does a quiafe lsd cost these days???? me thinking quite a bit
Duracel79
Post by Duracel79 »
Don't know the cost but the one found in my car is the same as fitted to E36 318i's and Z3's. I phoned them up to check what it was and how it should feel.
Bit of progress, my dad and his Dutch friend may have sorted out fitting the E30 4.1 ratio crownwheel and pinion into the E21 casing for me. Just needs blue-ing up to check the meshing but it feels OK. :P
I'll post up details of the bearings and shims needed for this conversion when I know it works well.
Duracel79
tommi_e21
Post by tommi_e21 »
sounds like good work! look foward to the report
charbel
Post by charbel »
so there is a LSD without plates for the e21?
that is interesting.. a picture will be nice. i had the yellow alpina i part out and it did now have a LSD as far as i know cause the wheels will not turn in the same directions..
anyway.. e28 diff you can use in an e21. same distance for the axles and same axles bolt patern. so all you have to do is mounted on your subframe .. i am not saying easy.. but it is easier then trying to fit any other diff in that car.. i know the e24 635 also fit on the e21. i have done it before..
good luck with the car
you laugh at me because i am different. i laugh at you because you are all the same.
http://www.facebook.com/people/Charbel-Haddad/505618590
http://s6.photobucket.com/albums/y235/charboula/
[img]http://i6.photobucket.com/albums/y235/charboula/ebay1018.jpg[/img]
Jason_323i
Post by Jason_323i »
Qualifies are about 700 plus vat
Jason
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
tommi_e21
Post by tommi_e21 »
is that 700 include all the casing or just internals to put into your own casing
Jason_323i
That's just the internals
Jason
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
Duracel79
Post by Duracel79 »
Jason_323i wrote:That's just the internals
Jason
Just why i was so pleased to find one in the casing :D :D
tommi_e21
Post by tommi_e21 »
prob another dumb ass question, are the externals same on open to lsd,s, eg if i bought quaife internals could i fit them in my open diff
Duracel79
Post by Duracel79 »
Yes, all fits.
Just need to swap the crown wheel and output bearings off the open diff and fitting them onto the LSD. It would be worth checking all the cearances once fitted together though.
I did a similar swap on my E30. There was a bit of play so I thought it would be OK. Done about 40k since and the diff has started to wine at around 60mph. Not too bad considering its got a strong 2.7 driving it.
Duracel79
