Just as soon as i have fixed up the exhaust and added some more zip ties to my oil cooler.Retrobeemer wroteHow soon will you be driving it to check out the performance?
I've got tomorrow off and hopefully being dragged around the shops to look at furniture will only take till lunch time and i can get into the shed for the afternoon.
murran wrote:cool gasket making skills there. the gaskets you get with aftermarket pumps are always shit.
looking forward to hear from you after driving it!
Believe me I'm looking forward to driving it. I will be posting some footage up on youtube of its first test run once i establish a place to wedge the video camera....
Can you use the one off your e21 manifold and jut add in a joiner and some extra pipe?Thayat wrote:Great result Varden. I have run into one or two problems myself.
The engine and componentry is missing a few vital bits. The vacuum hoses that connect the brake booster with the inlet manifold and the oxygen sensor (bugger). I have the e30 water pump with only the single outlet and also standard E30 325 fuel pump.
So if I am right, I either need to mount the fuel pump somewhere under the car (any photos of a standard E30 installation as google isn't helping), or get a 318is pump (not an option in NZ), or get an e21 323i pump to mount inside the tank???
With the water pump, I need to get an e21 one and mount it so I can keep the expansion tank. I take it there are no other solutions?
With the oxygen sensor, I have the standard e21 exhaust manifolds. Is it wise to mount to only one of the branches or should I run it along to the point where I will join the two pipes into one?
Its getting to the last bits and pieces. The troublesome ones.
Any guidance from anyone is welcome. I'm getting some pretty ordinary advice from my mechanic unfortunately.
Can you steal the water pump off your 320 motor or is it a 4cyl? I thought about making up a T junction out of metal tube and just cutting the hose that goes over the top of the timing cover and adding the junction there connected up to overflow bottle....but I didn't have any of those bit lying around to do it with so i brought a new water pump.
Any m20 up to 1988 should have the same waterpump as yours as it was the facelift model that went with the new arrangement.
As for the fuel pump i would start with the e30 325i in tank pump and go from there, i think the full 323i e21 twin pump set up is over kill as murran is running a modded 325i in tank fuel pump in his 320 hooked up to a 7.5 amp fuse to the motronic plug. If the 325i pump doesn't work out then try the e21 in tank pump and hope it is up to the job.
From what i've read on this forum the 02 sensor needs to be as close to the head as possible as its a narrow band sensor with no heater element (!!??).
I've only got the sensor in one branch mounted in the collector, getting both would mean the 02 would be a metre from the head, not flash.
Ordinary advice from your mechanic....
He probably thinks your bonkers! Unless he's a specialist then he's waiting for you to bring it to him to sort...$$$$$$$$$$$$$$$$
Man i would HATE to think what paying someone to do this conversion would cost. You'd be paying for their expertise afterall or worse yet you'd be paying them $100 an hour to stumble through it like we have!
