breaking e30 325i auto
- jimbolina316a
- E21 starter
hi all,
have just aquired an e30 325i auto thats being broken up for parts, please let me know if you need anything, a few bits have gone already but if you dont ask you dont get, will update you more tomorrow with more info
cheers
jim
cheers
jim
'83 316 auto
'03 330i msport
'03 330i msport
- jimbolina316a
- E21 starter
update
hi all,
the car is a schwartz black four door auto with 146000 miles on the clock and good history, there are a fair few bits missing but if you would like anything please let me know and will let you know
cheers
jim
cheers
jim
'83 316 auto
'03 330i msport
'03 330i msport
- jimbolina316a
- E21 starter
it bit akward to have a look as i am in ireland but thanks for the offer!!
on the back of the diff there shold be a metal tab on the top right hand corner above the speed sensor it sholud say the type of ratio on it ie. s3,46 or s3.25 and so on. also how many bolts holding the back plate on to the diff.
- jimbolina316a
- E21 starter
- --ALPINA--
hi paddy, have you tried looking in the http://www.e30zone.net and try the wanted section for an LSD its all lovers for the e30 maybe they can also help you failing jims car.
J
J
- jimbolina316a
- E21 starter
hi all,
just had a look, there are two bolts holding the very back plate onto the diff, also, when you rotate one wheel, the other rotates in the opposite direction as its on axle stands already this was all i could do, the little metal plate i had to break off as had to wire brush it but it say 3,73 then an space then 842, hope this info helps
cheers
Jim
cheers
Jim
'83 316 auto
'03 330i msport
'03 330i msport
- jimbolina316a
- E21 starter
