M10 to M42 Getrag 240 mechanical speedo conversion
alschux
Re: M10 to M42 Getrag 240 mechanical speedo conversion
Post by alschux »
This is a great piece of work, got me thinking about the M42 swap all over again!
nuke laars
My E21(s): 1983 Baltic Blau 316
Post by nuke laars »
Would I be right in thinking that you could just source a bellhousing from the more common getrag 240 (E30 318i) seeing as you can bolt an M42 straight to it?
1983 Arctic Blau 316
1989 Sterling Silber 318i
Sierpien
Post by Sierpien »
nuke laars wrote:Would I be right in thinking that you could just source a bellhousing from the more common getrag 240 (E30 318i) seeing as you can bolt an M42 straight to it?
Yes, but you don´t have mechanical speedo!
Alex von Falkenhausen
joe14
My E21(s): 1983 black 316
Re: M42 Getrag 240 mechanical speedo conversion
Post by joe14 »
A great write up, I've just done this myself:
http://www.bmwe21.net/forum/viewtopic.p ... 2&start=90
What I would add to this is to expand about the lateral plug:
Sierpien wrote: Also very important the lateral plug, that holds all the mechanism in place, if you don´t take this out yo can´t separate the 2 housings:
The plug in question is this:
We struggled initially because we thought this was just a blanking plug.
There's not much room under neath to get under it so we welded some threaded bar on but we managed with a screwdriver for the second box.
Once this is out and all the other bolts you really don't need a lot of force to get them separated.
[img]http://i1380.photobucket.com/albums/ah1 ... rp.jpg[img]
