My 320/6 automatic
Hey,
Ofcourse they will be removed. My intension was to strip the car complete. Including motor, transmission, fuellines, brakelines, fueltank wheels, Subframe etc. etc. So it almost becomes a full body restauration.
Behind my house i have a double garage so i can store the stuf and then make a hopefully nice E21.
But this way of working takes a lot of time. And me doing it al by myself saves a lot of money.
Somethings i have done before but the most things are new for me so I need the forum for sure.
Greetings Peter V.
Greetings Peter V.
Today a little bit of work done.
* Removed the safety-belts at the rear.
* Removed both side windows and the chrome trim along with it.
* Removed the rear window.
Not to much rust discovered. There has been a bit of welding on the B and C-style but the previous owner did it well.
Greetings Peter V.
[/img]
Greetings Peter V.
[/img]
Hey
A little update,
Not much work done except cleaning and storing all the parts.
Today i bought the front and rear bumper in excellent shape. They are originals not imitation.
Greetings Peter V.
A little update,
Greetings Peter V.
Hey,
Just a question:
How do i remove the roofcarpet ( good english
Greetings Peter v.
Just a question:
Greetings Peter v.
- Mcinek
- My E21(s): '80 BMW 323i
You mean the headliner. First you need to remove all windows (front and rear especially) and sealings. Under the headliner you will find 5 metal struts holding the headliner on its place. First turn them 180 degree and remove them. It's very simple.Peter V. wrote:Hey,
Just a question:
How do i remove the roofcarpet ( good english![]()
Greetings Peter v.
BMW "Freude am Fahren"
Marcin
Marcin
Hey,
A little update:
Today removed the interior of the doors and the headliner. Thanks for the tip, it went perfect.
Glad i decided to remove the headliner. A little bit of rust came free and the headliner has had some moisture in the past.
Greeting Peter V.
A little update:
Greeting Peter V.
Okey,
Did some work today. I have been started with the bumpers. Cleaned the inside and protected it with a coating. Also polished the outside of it.
After that i started with the doors. Completly stripped them.
Greetings Peter V.
Greetings Peter V.
Hey,
I have been removing my doors. I have a Question about the pen which hold the doors open. Is there a easy way to remove these?
Greetings Peter V.
Greetings Peter V.
- Jekyll66
Hey Peter,
on my left side it goes easy, but on the right side I had problems too.
The pen on the right side i had to bump with hammer and drift. Perhaps you have to cut him with a very small metal cutting machine.
The pen you will get new one.
Greetings Stephan
Greetings Stephan
Completely storie of restoring TC1: http://3er-foren.de/showthread.php?tid=7965
[url=http://www.baur-tc1.de][img]http://i25.tinypic.com/2wrhrht.png[/img][/url]
Okey,
Thanks Stephan, It means that I did not do it the very wrong way then.
By the way, checking your topic at the german forumsite and I'm jealous of your work, it looks very nice.
Again thanks for the respons.
Greetings Peter v.
Greetings Peter v.
Today removed the other door. This one was a lot faster to do.
Next is to empty out the engine room so that the engine and transmission can be removed.
Greetings Peter V.
Greetings Peter V.
Yesterday i had a lot of wordk done:
-Removed the coolingsystem completly.
-Removed the alternator.
-Removed the startermotor.
-Removed the exhaust completly.
-Removed the drive axle ( The bolts at the Dif-side were very difficult to remove.
Now only have to empty the fueltanks and remove the Fuellines and the engine and transmission can be removed.
Update,
The engine is still in place because i'am waiting for the right equipment.
Yesterday i removed the rear suspension completly and did not get any surprises. The upper mounting area of the shockabsorbers are in good condition. Today removing the gastanks so that the rearside of the car is completly stripped.
Leftside:
Rightside:
Greetings Peter V.
Leftside:
Rightside:
Greetings Peter V.
