It needs itaustin25uk wrote:gonna buff it right up!!!!
I'm hungryyyy when are we having lunch??
that should only effect the compression ratio. capacity is determined by bore and stroke.austin25uk wrote:the gudgeon pin is slightly higher meaning the piston sits lower therefor giving more capacity i think
Think what he should have said was, the higher pin allows a longer stroke crank to get the piston to the top of the bore, IE 2.0l crank more capacity.340i wrote:that should only effect the compression ratio. capacity is determined by bore and stroke.austin25uk wrote:the gudgeon pin is slightly higher meaning the piston sits lower therefor giving more capacity i think
awesome score on the wheels. wanna send a set to nz for me?!
