If you need the odd M10 bit I have several motors to pick from.
Project - 320 TSi
spent another 4 hours with the help of tamsin sanding and polishing 2 more dish's with out the stupid anodized surface. got 1 more polish to do tonight when im home after work and gotta rub it all down with lime or sumin according to the polishing guide and should be good. im afriad there not mirror shine but still pretty good, will get it profsionally done eventually when i can be arsed.
centers will be sprayed black by monday and i can start putting the whole lot togther
here are some pics
here are some pics
- Pho21_girl
right, the wheels are 9.5 j fornt and 10j rear with rear having a larger positive offset so more poke on the rear.
tyres will be 225 45 16 on rear and 215 on the front so should look pretty good, only a tiny bit of stretch, got bored of constantly having to refit the tyres on the banded steelies
oh and here is a pic of the wheel centers sprayed matt black, just wiating for the gloss black paint to turn up and then its laquer time and rebuild
dont forget some pics
cant wait to see it when the rims are on
E36 328i Daily driver
E36 328i Touring
E36 328i Touring
new engine is all in, done a few service items and bits n bobs and tried to fire her up....... didnt fire
cant get the timing sorted yet
. gonna have another crack at it tommorow night. got some nice backfiring though. thing is none of the carbs are balanced and not timed and its tricky getting all the things to work at same time.
paint arrived today
once engine is running can get round to spraying it
paint arrived today
got engine running,
found the reason why she wasnt running, the spark plugs had the wrong tips on them so the leads where not locating onto the plugs, unfortunatly when i checked this the first time i only checked plug 1 which had the right end on it so i ruled it off. whoops. still its got 4 plugs new dizzy cap and roter and she runs alright
webbers are still causing interesting running issues. it idles a lot better but still pisses around a bit. revs nicely though with the bigger valve head.
just need a throttle cable now and whoop away she goes. (please see wanted add for 323i throttle cable)
wheels are now gloss black so just waiting to get some silicone and then i can build them and fit some new boots to them, will require a little arch modification to get clearance i think now but nothing i cant handle.
all paint has arrived so that can be done now atleast this weekend. and have nice shiny car
oh and still need road tax
and fuel and then woooooooo baby its run to the sun. wont be a couple o pics on here till after wknd now so you get the final product
