Problemchild75s 1983 safari m52
problemchild75
Re: Problemchild75s 1983 safari
Post by problemchild75 »
bit of an update to keep my thread up to date.
all rear suspension parts and tanks powder coated and poly bushed (strongflex)
then stripped the m52 downof all the unnecessary parts, replaced all the gaskets and seal, fitted a M50 inlet and a lowered sumpand pick up from Nas :thumbsup
then gave the underside a couple of coats of rust bullet
then a coat of colour all ready to start re assembly :mrgreen:
pulled the heart out next. No going back now
Nice work so far mate. Defo won't beta half arsed job.
Keep the loom off the old engine. You need the plug that goes to the fuse box.
Danny043
Post by Danny043 »
Good work !
problemchild75
hopefully wont be half arsed ...................................with your help lol it would have been a crime to bodge it up as it was almost a crime to pull it to bits in the 1st place.
not throwing anything until I check first with the boss man. just wish I had more time to play with it as it stands at the moment im happy when I dont book jobs in so I can crack on so ill be bankrupt by the time its finnished.
raseeda green
Post by raseeda green »
Really like your car, and the conversion. Can't wait to see it one day in the metal. Cheers
316 auto raseeda green
323 red m52 modified
problemchild75
cheers
pulled out the servo,pipes, wires and sound proofing today then gave it a quick jetwash. i was tempted to leave the engine bay and get the lump in but I knew I would always be kicking myself if I did, Ill give it a propper clean next prep it all and give it some fresh paint before re build. not much corrosion considering its age and what is there is only surface rust. do I go to the trouble of hiding all the wiring and smoothing the bay though?
Definitely in well above average condition and now is the best time to put things right!
Yea looks like you will have to spray it anyway - engine bay smoothing is a good idea but in an e21 the engine they are really bumpy.
i cut all the brackets off, but thats as far as id to go as it feels strange to have lots of filler in the engine bay.
problemchild75
Hmm I think it might end up a nightmare filling it all.
New back plate and paddle clutch arrived today :-)
Omg lol. Unsprung as well! Are you going to get fed up with lighting up your tyres or stalling.
problemchild75
Do you ever really tire of lighting up your tyres. The 6 paddle is sprung but unsparing will be better for the supercharger power ( non of that turbo nonsense). Cheers for the bits today pal I still think you should have given me that steering link rod. :-). Your car would look better stopped out with bucket seats I'll help if you want and move your old interior
problemchild75
cut off a few bits out of bay and atacked the service rust with wire wheel, rust treatmeant then rust bullet. rain stopped play so I didnt get chance to prime and paint ( I should have given the VW show a miss this morning. then I fitted the return fuel tank, re fitted the rear tanks and started re assembling the rear beam. ( the rear arb bushes are a bitch to fit any tips?) also an e30 318is fuel pump is not a direct fit you need to cut it down a bit.
todays pics
drjim
Post by drjim »
It's very odd, I have had 2 or 3 e30 pumps fitted straight into the slug and my Baur without any cutting down. Fuel gauge is always wrong though!
1982 Saphirblau Baur 325i
Cars all gone!
problemchild75
can you correct the gauge Jim? I thought it was me at firstwith the pump but I had my mate look aswell. it was a second hand one though so I dont know where it came from really. I gave up trying to clamp the poly arbs inand packed up in fustration.
drjim
Post by drjim »
Too much effort to fix it. Basically full is full, and the low level light tells the truth, still shows 1/4 tank when the light comes on.
Cars all gone!
